56 225 hp cam needed - NCRS Discussion Boards
  • Mike M.
    • May 31, 1974
    • 8382
    rebuilding the 265 ci engine in my 56 and the machine shop can't find an aftermarket camshaft. anybody got suggestions. thanks,mike
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: 56 225 hp cam needed
    how about this cam? http://stores.thunderchickenauto.com/Detail.bok?no=114
    • Clem Z.
      • January 1, 2006
      • 9427
      3711354 cam specs. IO 21 BTC, IC 62 ABC, lift .404. EO 62 BBC, EC 28 ATC, lift .413
      • David A.
        • July 31, 1999
        • 147
        hi mike
        have you posted any pictures of your 56 anywhere?
        dave
        • Mike M.
          • May 31, 1974
          • 8382
          No. Not computer literate but learning.mike
          • Joe R.
            • July 31, 1976
            • 4550
            Mike,
            Ultradyne, Inc. will grind a cam to your specifications. They can be reached at 1 601 393-3214.
            JR
              • 15667
              Is the OE cam hydraulic or mechanical lifters?
              • Clem Z.
                • January 1, 2006
                • 9427
                3711354 was a solid lifter cam.
                  • 15667
                  The trouble with these data is that I think they are lash point durations (durations work out to 263/270 and if the lobes are symmetrical then the POMLs are 110.5 and 107, so the LSA is only 109.75 ), which nobody but GM ever specfied. If we had SAE J604d data and .050" lifter rise data - either above the base circle or preferably above the tops of the clearance ramp, then Mike might be able to find lobes in the Crane library that are close.
                  Mike - what's the idle behavior of this engine: idle speed in neutral @ manifold vacuum? (I assume it's a manual trans.)
                  • Clem Z.
                    • January 1, 2006
                    • 9427
                    the SAE specs list the duration at 264/266,overlap at 45 degrees with lash at .008/.018. i ran this cam in my new 55 chevy power pack back in the mid 50s along with dual 4 barrel carbs because i could not afford a corvette so i just put the corvette engine parts in the 55. below is the tool i used to change the valve springs that came with the cam. it fit over the rocker stud and you used a nut on the stud to compress the spring with air in the cylinder to hold the valve closed
                    • Clem Z.
                      • January 1, 2006
                      • 9427
                      this cam was used with a PG transmission in 56 corvette
                      • Bill B.
                        • December 1, 1993
                        • 192
                        Check with Thunderchicken, I believe all their camshafts are CNC machined & index from a NOS camshafts, so it should be the real deal. Recommend confirmation through Cam Doctor.
                        Bill
                        • John S.
                          • July 29, 2009
                          • 640
                          i have purchased camshafts from ebay vendor "chevyssbest". buy it now price was $60.00. it is a solid lifter camshaft, part #3711354 casting #3711355 known as the 355 hi lift. solid lifter cam with 264 int. dur. 266 ex. dur. .404 int lift and .413 ex lift. Valve lash .012 int .018 ex. Cam has notch in rear journal. vendor mentioned he been doing this for 35 plus years and could duplicate any 50's or 60's chevy camshaft.
                          • Mike M.
                            • May 31, 1974
                            • 8382
                            duke: the 55 and 56 265's ran solid lifter cam, 3711354. the engine, in stock config , should idle at 600-1000 rpm in neutral(the 56 i'm doing is a 3 speed.). thi8s cam was also uised in the 56 pass cars with 2 x 4 carbs. mike
                            • Adam S.
                              • July 30, 2008
                              • 167
                              Duke, decided to go with the thunderchicken cam for my 270 hp instead of the GM Duntoff nos cam I have, I found no problems, miked it along side with original "almost" exact duplicate Mike , hope this helps as a option for you.
