56 paint formula - NCRS Discussion Boards
56 paint formula
  • Joe E.
    • April 1, 1985
    • 77
    56 paint formula
    Does anyone have the paint code for DuPont for 56 red and white.
    Thanks joe
  • Paul O.
    • August 31, 1990
    • 1716
    Re: 56 paint formula
    Joe
    Here are some old numbers
    Venetian Red Ditzler PPG 70694 DuPont 59388
    Polo White Ditzler PPG 8011 DuPont 57758
    Hope that helps for now.
    Paul 18046
    • Adam S.
      • July 30, 2008
      • 167
      Hi Joe, how about an original copy out of paint chart............ Also take note of 90217 dark blue metallic, WOW!
      Last edited by Adam S.; July 25, 2011, 09:29 PM. Reason: picture add on number three
      • Bruce B.
        • May 31, 1996
        • 2930
        Joe,
        Here are some more old numbers: they are the same for 1956 and 1957.
        Venetian Red DuPont--2415-H, R & M--56V52R, Ditzler--DAL 70694
        Polo White DuPont--1783-H R & M--54V91, Ditzler--DAL 8011
        As you know these numbers are pretty useless as are old original formulas, due to the fact that the colorants and other materials are no longer in existence.
        I had Savage KOI cross reference Venetian Red and the pint they mixed was no where near what I percieve as the original color.
        I ended up painting the car with DuPont ChromaBase #44128K which is a National Fleet Color called Bright Spitfire orange.
        I choose the color from the Color Map book which was supplied by Sikkens.
        If you want to look at the Color Map book give me a call.
        • Peter V.
          • June 2, 2008
          • 116
          I recently saw a '57 in a collection in Massachusetts that was Venetian Red. The owner expalined that he couldn't find or match the original color to his satisfaction until he found a Ford paint color called "poppy". He claims it to be a dead-on match for Venetian Red.
          • Bruce B.
            • May 31, 1996
            • 2930
            Joe,
            Joe,
            The paint I used was a base coat formula and I am not sure if it is available in a single stage, assuming thats what you need.
            Bruce
            • Loren L.
              • April 30, 1976
              • 4104
              Thanks joe
              Exterior or interior?
              • Joe E.
                • April 1, 1985
                • 77
                I am looking for red for interior and white for outside. I thank all who have replied and will probably need to get something scanned to see how close I can get.
                joe
                • Loren L.
                  • April 30, 1976
                  • 4104
                  11/29/55 Chevrolet bulletin shows 1783-H (Dupont stock #, complete with footnote noting it as a "Repeat from previous production"; it also shows 2415-H as "Venetian Red" BUT this carries a footnote that reads "Good match to Standard - release for use ONLY in touchup".
                  Dupont letter dated 12/14/55 repeats the information above to Dupont shops.
