Yet another door question - NCRS Discussion Boards
  • Rob M.
    • April 30, 2003
    • 657
    Okay,
    The AIM doesn't call out any type of caulk or sealant on the door handle back plate (mounted inside the door). However, both of mine had some type of black sealant around the push button side (between the plate and the fiberglass) - I'm not talking about the gasket on the outside between the handle and the door.
    Is that the work of a prior owner or was that factory? If factory, what was it?
    • 6955
    Re: Yet another door question
    Originally posted by Rob Myrick (39795)
    Okay,
    Bob, the only problem I see with sealant around the push button,Is if the sealant get into the push button rod it may cause the button to stick.maybe a little chaulk around the bolts that mount the handle
    • Tom A.
      NCRS Body & Paint Advisor
      • May 31, 1986
      • 138
      The sealer your referring to was likely used to hold the plate in place while the bolts were installed. I've seen it on some and not on others. Probably a line workers short cut. 3M strip caulk (dum-dum) works well.
