1960 Parking Brake Adjustment - NCRS Discussion Boards
  • James S.
    • June 22, 2008
    • 226
    A couple of questions please.
    I assume you adjust the rear brake shoes firsat for proper drag then adjust the parking brake cable.
    The 1960 Assembly Manual describes a 25-35 ft lb tension on the T handle when pulling, but doesn't describe how to adjust the front cable and two rear cables. I can pull the rear cables and feel a detent where I assume is the point where the shoes begin to expand, but again not sure of the front cable for proper adjustment.
    Any assist is much appreciated.
    Jim
  • Gary C.
    Administrator
    • October 1, 1982
    • 17659
    Re: 1960 Parking Brake Adjustment
    James,
    Recommend you purchase a ST-12 - the Corvette Service Guide.
    Copies of 5-2 & 5-4 how to adjust the parking brake cables attached.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • James S.
      • June 22, 2008
      • 226
      Originally posted by Gary Chesnut (5895)
      James,
      Gary
      Gary,
      Thanks, I have the AIM and th 59-60 passenger car shop manual. Is the ST-12 specific to the 60 Vette?
      Can you send page 5-3 where drag adjustment info is continued?
      Jim
      • Gary C.
        Administrator
        • October 1, 1982
        • 17659
        Jim, ST-12 specific to C1 Corvettes. If you working on C1's you really need the ST-12 Corvette Service/Shop Manual. Gary....
        NCRS Texas Chapter
        • Donald H.
          • November 2, 2009
          • 2580
          James, I have a 60 that I've been restoring. If you are doing any work yourself you need the ST-12. the actual title is 53-62 Corvette Servicing Guide, and you can order here in the NCRS store.
          Don Harris
          Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
