Front wheel bearing - NCRS Discussion Boards
Front wheel bearing
  • Steve V.
    • June 27, 2011
    • 95
    Front wheel bearing
    What is the proper way to remove the inner race of the inside front wheel ball bearing? Mine are on pretty tight. I don't want to try force if there is better way.
    Steve
    Opportunity is missed by most people
    because it is dressed in overalls and looks like work.
    Thomas Edison
  • John F.
    • March 23, 2008
    • 2415
    Re: Front wheel bearing
    Take it to a machine shop! They can press it out.
    • Steve V.
      • June 27, 2011
      • 95
      Not the outer race in the hub, but the inner race on the spindle.
      Thomas Edison
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11334
        This one?......Maybe try some heat with a propane torch? Then a few taps with a tapered cold chisel around the perimeter where it seats onto the backing plate. If I recall they are a slight press fit.
        When I did these I had everything apart so I think I just put the nut on the spindle and tapped it with a brass hammer while supporting the backing plate.
        Rich
