Rochester vs Carter Quadrajet on POP - NCRS Discussion Boards
  • Cliff K.
    Infrequent User
    • November 1, 2003
    • 20
    I recently looked at a 1968 327/300 that has a correctly dated Carter Quadrajet carburetor. However, the owner protect-o-plate has the "R" designation for a Rochester carb. We know that Carter made the Quadrajet for several years because GM, for whatever reason, wanted additional capacity to supply the Quadrajet.
    Question is; should the POP show a designation of "C" if the original carb was a Carter built Quadrajet or would it continue to show the "R" since the Carter was additional production (even used the same number system as the Rochester) for the Rochester Quadrajet? Does the "R" designation indicate a Quadrajet carb regardless if made by Rochester or Carter?
    Appreciate your sharing of experience on this subject.
    Cliff Kennedy
    • 15635
    Re: Rochester vs Carter Quadrajet on POP
    The "R" designation indicates a Quadrajet carb regardless if made by Rochester or Carter.
    • Jim T.
      • March 1, 1993
      • 5351
      My 68's POP also shows R. Don't remember if the original carb was a Carter or Rochester, it was replaced by the 68's warranty. The replacement was removed in 1974 and I installed a Holley 650 spreadbore 6210 double pumper that remains in use.
      • Cliff K.
        Infrequent User
        • November 1, 2003
        • 20
        Terry,
        Thank you
          • 43285
          Jim------
          Carter was not manufacturing Q-Jets as early as 1968, so all original 1968 Q-Jets will be manufactured by Rochester, Carter "got into the act" about 1970.
          • Pat M.
            • April 1, 2006
            • 1582
            My 70 has what I believe to be the original Carter carb and the POP shows a "C".
              • 11697
              Picture of the POP?
              I'd be interested in seeing that, even if you block the end of the VIN.
              Patrick
              • Pat M.
                • April 1, 2006
                • 1582
                Picture of the POP?
                Patrick
                Sure, here you go:
                • Jason R.
                  Infrequent User
                  • December 31, 2009
                  • 18
                  My 70 has a "C" on the POP also. The carb is a Carter.
                    • 11697
                    Thanks.
                    Any other examples of C for Carter, or R on a car with a Carter-built Rochester?
                    Patrick
                    • Jim T.
                      • March 1, 1993
                      • 5351
                      My 70's original carb is a Carter manufactured Quadrajet #704202 FO DH and has the C on the POP.
                        • 15635
                        I learned something new here.
                          I'm looking at the '71 AIM, Section 0, Sheet B3. It defines the field codes used for POP emboss. The selection choices for the Carb Source field (holarith position C-11) are:
                          B Bay City
                          C Carter
                          H Holley
                          R Rochester
                          To confirm this is true for other years, consult the applicable AIM...
                            • 11697
                            B Bay City
                            C Carter
                            H Holley
                            R Rochester
                            I'm just surprised that anyone in the plant would have taken the time to check the carb to see where it was made. I suspect that there must have been something on the paperwork indicating this, but even that surprises me. Had these been actual Carter brand (as opposed to subcontracted) that would be different.
                            Patrick
