1967 underside question - NCRS Discussion Boards
  • Mark U.
    • June 7, 2009
    • 70
    what shall i do with the enderside of my 67 vert. It is having a frame off and there has to be 1-2 small repairs,should i paint it the color of the body or? I would like to get this judged after it has been completed,i know the underside from the factory was bare if i am correct. this car is a 427 powerglide car.
    Thanks for the help
    Mark
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: 1967 underside question
    The underside was bare glass. I'd repair the problems and try to make them as inconspicuous as possible. Don't paint body color as this would be a deduct. If you correctly finish the various brackets etc to original this would probably minimize the repair differences.
    • Russ S.
      • April 30, 1982
      • 2163
      Use a dye in the resin to match the original fiberglass color.
      • Gene M.
        • April 1, 1985
        • 4233
        Mark,
        You will generally find some paint overspray (primer and/or finish color) along the floor pan adjacent to the frame side rails and on the sides of the stowage tub.
