Aim Manual - NCRS Discussion Boards
Aim Manual
  • Terry L.
    • March 14, 2010
    • 53
    Aim Manual
    AIM Manual, What is it and where can I get one, I did a search and looked in publications, thanks for your help Terry
  • Gary C.
    Administrator
    • October 1, 1982
    • 17971
    Re: Aim Manual
    Terry,
    AIM's are available from the NCRS Store.
    The AIM's are down close to the bottom of the page.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Terry L.
      • March 14, 2010
      • 53
      Re: Aim Manual
      Thanks Gary, I just missed seeing it, Terry
      • Paul J.
        • September 9, 2008
        • 2091
        Re: Aim Manual
        AIM - Assembly Instruction Manual. The instructions for putting your car together, kinda like the instruction sheet for a plastic model, only bigger.
        • Joe R.
          • May 31, 2006
          • 1822
          Re: Aim Manual
          You can also get an electronic version from Willcox Corvette.
          Joe
          • David H.
            • June 30, 2001
            • 1578
            Re: Aim Manual
            The A.I.M. (Assembly Instruction Manual) is a bit of a misnomer, really a Product Description Manual. As such, it contains much assembly information, but, the manual is divided in sections per the Uniform Parts Classification (UPC).
            The upshot is, it is sometimes difficult to find the information you are looking for. Most vendors also sell an AIM INDEX specific to each year - an index will help a lot.
              Re: Aim Manual
              Every A.I.M. has an index built in, if you know how to use it; here's a link to an article on understanding the Assembly Manual:
                • 15646
                Re: Aim Manual
                If one works with or around the GM parts system long enough the parts group system becomes second nature. Back when parts books came as books the good counter persons could open the parts book to the group they wanted on the first try. The computerized system has eliminated the need for that skill, but they still need to know what group covers which area of the car. Keep using the AIM and you will get the hang of it.
                  Re: Aim Manual
                  Terry -
                  And, for whatever reason, the GMPD/GMSPO parts guys never talked to the Engineering guys when they set up their "Group Number" system; the only parts Group number whose content matches the Engineering UPC Group number content is Group 5.00 (brakes), and brakes are split between Group 4.00 and 5.00.
                    • 43295
                    Re: Aim Manual
                    Terry -
                    ....and brakes are split between Group 4.00 and 5.00.
                    John------
                    Yes, one of the dumbest things they ever did.
