Ammonia Smell - NCRS Discussion Boards
Ammonia Smell
  • Gerald C.
    • June 30, 1987
    • 1311
    Ammonia Smell
    I'm looking at a car that has a very strong "ammonia" smell in the car. It has no rugs, no door panels to hold that smell.
    I'm not concerned how the smell got there, but how do I get rid of it if I buy the car???
    Some folks tell me that a cat visited the area, but.....
    Thanks for your help,
    Jerry
  • Joel T.
    • April 30, 2005
    • 765
    Re: Ammonia Smell
    Gerry,
    Could be a cat or something may be freshly dead in there somewhere.
    Joel
    • Michael D.
      • June 30, 1996
      • 536
      Re: Ammonia Smell
      Change the cat box.
      • Keith L.
        • April 7, 2008
        • 378
        Re: Ammonia Smell
        I would call a pet store and ask how to get rid of the odor weather if it originated from a cat or not. Just tell them it did and what should you use. If it will get the cat pizz smell out it will probably take care of it. Hard to figure what is holding the odor without carpet and such. Maybe it has been absorbed by the fiberglass floor pans.
        Good luck and don't let a cat near it as he will try to cover with his sent?
        • Chuck W.
          • May 31, 2002
          • 257
          Re: Ammonia Smell
          There is a product called "Nature's Miracle" thast is basically an active enzyme that will eliminate most pet odors is applied several times. It can be found at most pet stores. I would spray exerything down and let the enzyme work for at least 24 hours, then scrub the entire interior with a strong detergent then repeat the enzyme treatment and scrub again after 48 hours or more.
          If the odor is from an animal it should eliminate it.
          • Michael M.
            • February 1, 1993
            • 606
            Re: Ammonia Smell
            Are you sure the smell is from a animal. Maybe the previous owner had trouble with animals and put moth-balls in the car. Moth-balls have a strong smell like ammonia.
            • Christopher R.
              • March 31, 1975
              • 1599
              Re: Ammonia Smell
              Fabreze is supposed to treat this condition too. But pet stores probably have better stuff.
                • 6958
                Re: Ammonia Smell
                Jerry
                Jerry, look into the foam in the seats maybe something crawled under one of the seats and made a home.
                • Jim R.
                  • June 30, 2001
                  • 643
                  Re: Ammonia Smell
                  That sounds like moth balls to me also.
                  • Gerald C.
                    • June 30, 1987
                    • 1311
                    Re: Ammonia Smell
                    Thanks everyone for some great solutions. Maybe I can use the smell as a negotiating tool!
                    Jerry
                    • Gary B.
                      • September 30, 1987
                      • 305
                      Re: Ammonia Smell
                      Could it be from Flood damage? That is why the carpet was taken out?
                      • Michael F.
                        • June 4, 2009
                        • 291
                        Re: Ammonia Smell
                        Originally posted by Michael Davenport (27810)
                        Change the cat box.
                        In my 15+ yrs in the detail business. Cat urine is the one thing I couldn't ever get out.
                        Ever seen the Seinfeld episode with the body funk tainted BMW? Couldn't sell it. Even the theives wouldn't take it. Similar issue.
                        • Joe R.
                          • July 31, 1976
                          • 4552
                          Re: Ammonia Smell
                          BINGO!!!! I think we have a winnner!!!!
                          JR
                          • Joel T.
                            • April 30, 2005
                            • 765
                            Re: Ammonia Smell
                            Was the car left outside for an extended period of time?? My kid brother left a car at my place, outside, for a number of months, and members of the rodent clan moved in... They set up housekeeping in the climate control system and left many many little calling cards in there... the ammonia small was terrible and when you turned on the system, "stuff" flew out of the air ducts...
                            My brother complained about this turn of events to which I reminded him that storage and associated mouse poop did not cost him a dime, and had he spend a few bucks to store the car properly, all this would not have happened!
                            Bottom line, if the car has been outside for some time, you may want to take the heater out and see what is in there.....
                            Joel
                            • Paul J.
                              • September 9, 2008
                              • 2091
                              Re: Ammonia Smell
                              Jerry, products like Nature's Miracle work very well if the problem is from a cat. However, you need to find the offending area and address it. Is it the seats? Is it the firewall insulation? Is it in the heater box? If it's as bad as you say it is, then there will always be some remnant of the odor, even after you've treated or replaced the parts which are contaminated.
                              You might want to keep this in mind in your negotiations.
                              Paul
