Attn: Joe Lucia/Smog Pump Pulley Number - NCRS Discussion Boards
  • Larry E.
    • 1702
    This may possibly apply to Corvettes.
    Joe:
    Replacing my Smog Pump Pulley for my original 69 Z28. I am putting on
    #3932458 which I'm told is the correct one. The one I'm taking off is
    #0610159 which looks the same and has the "Deep Groove" on it. Do you
    have a record of where the #0610159 was used or is it a replacement
    pulley? Thanks in advance.
    Larry
    Larry
    LT1 in a 1LE -- One of 134
    • 43289
    Re: Attn: Joe Lucia/Smog Pump Pulley Number
    Joe:
    #0610159 which looks the same and has the "Deep Grove" on it. Do you
    Larry
    Larry------
    I can find no record of a pulley with a GM part number of 610159. However, it's possible that such a part existed. If it did, it was a TRUCK part number (i.e. medium duty or larger truck).
    • Larry E.
      • 1702
      Larry------
      Joe:
      Is it typical of a truck smog pump pulley to have the deep groove on them?
      Larry
      Larry
        • 43289
        Joe:
        Larry
        Larry------
        I'm not familiar enough with these MD/HD truck parts to say. Does this pulley with part number 0610159 have a "GM" embossment anywhere on it? If not, this may be some sort of aftermarket piece.
        • Larry E.
          • 1702
          Larry------
          Joe:
          When I get it off I'll take a picture of it and post it for all to see.
          Larry
          Larry
          • Larry E.
            • 1702
            Larry------
            Joe: Here is some pictures of those pulleys. Any clues from them?
            Larry
            Larry
              • 43289
              Larry
              Larry------
              The GM #3932458 is easy. It was used for 1969 L-46 as well as later applications with C-60.
              The other pulley I can't say. It's obviously an AIR pump pulley and it looks to be a GM pulley. However, I have no record of that part number. It's definitely not a Chevrolet part number (but could have been used on Chevrolets).
