Another 1966 L-72 3864480 Pulley question - NCRS Discussion Boards
  • Glenn B.
    • February 22, 2011
    • 19
    Hello,
    I have read all the archived pulley threads until I am cross eyed but..
    Since an original 3864480 pulley cannot be bought for reasonable sums of money, will the 2 groove Hi-Per SB pulley 3770245 be a interchange on a no power 1966 L-72?
    The dimensions between the two appear very similar. I dont really care about installed belt lengths, but I have a nice 245 pulley, and I dont really want to take the car apart to find out it wont work!
    Any help would be appreciated.
    Glenn
    • 43287
    Re: Another 1966 L-72 3864480 Pulley question
    Originally posted by Glenn Blanton (52962)
    Hello,
    Glenn
    Glenn------
    The 3770245 might work but I greatly doubt it. The 3770245 was a small block pulley and, while it has the same flange pattern as the 3864480, the rest of the pulley is differently configured.
    The GM #3864480 was discontinued in December, 1966 and replaced by the GM #3906656, the 1967 big block pulley. Unfortunately, the 3906656 was discontinued quite some time ago and can be extremely difficult to find, too. However, I think it's reproduced.
    • Keith B.
      • March 7, 2008
      • 928
      https://www.paragoncorvette.com/p-34...mp-pulley.aspx
      • Glenn B.
        • February 22, 2011
        • 19
        Thanks for the feedback Joe and Keith,
        I had seen the reproduction, just thought I might could run the 0245 pulley since I had it on hand. It so very close to the 4480 dimensions, same diameter +-1/16, same offset, I am tempted to bolt it up and just see if it works!
        But then if it chucks the belts...I might not be so happy.
        Glenn
          • 43287
          Glenn
          Glen------
          I would check to see if the pulley grooves line up the same relative to the flange mating surface.
