Hood latch phosphate color
Re: Hood latch phosphate color
The parts were "parkerized"
the color is a dark gray with small glittery metalic in it.
If you put it in the sun, there will be a very subtle sparkle.
The magenese phoshate is correct (like Alan said) and there are kits available on the internet.
You may want to look up Grant Wong on NCRS TDB - he has all kinds of neat phosphating products...
It is a Hot water process - not cold like black phosphating.
They are the very best in the business.
Discover Brownells, the oldest U.S. company specializing in gun parts and gunsmithing tools since 1939. Shop high-quality gun parts and gunsmithing tools for firearm enthusiasts and professionals.
Great source for "parkerizing" chems Brownells gunsmith supply.
http://www.brownells.com/
Now you know my other hobby.Vice-Chairman (West), Michigan Chapter NCRS
Patrick------
Yes, different part numbers and not interchangeable, although very late 1969-76 left side upper can be used on 1968-L69 if the very late 1969-76 lock bolt is also used. I don't recommend it, though.
There may have been different manufacturers of the two series of plates. The 1968-L1969 were manufactured by a firm that used the symbol of an "M" or "W". I don't recall what the very late 1969-76 manufacturer's symbol was. (I have some NOS examples of these but I'm too lazy to dig them out right now).In Appreciation of John Hinckley- Top
Now you know my other business. I am a gunsmith and dealer.- Top
Larry,
Consult with your plater regarding plating the spring(s). Depending on the process he uses there may be some damage to a spring during plating. You might have to remove the spring(s) if your plater recommends doing so. If it were me I would remove them anyway.Terry- Top
Parkerizing should not affect a spring's function or strength. Other plating will, of course, affect a spring very differently.Vice-Chairman (West), Michigan Chapter NCRS
Terry,
Thanks for the tip; I'm not contemplating plating anytime soon. I was more interested in a 'for my info' answer, for if/when I do replate.
Most likely, I'd get the kit and supplies to do it myself.
Larry- Top
This hood latch thing drives me crazy, for the 68. I think I posted this before, but look at the three different versions for a 68. I think they are oldest right to left. Would you have the #'s and info. on them Joe L. The colors look all about the same though. Had to reload cause the file was too large
DCAttached Files- Top
BTW: When we did Parkerizing in the research institute in the late '60s a bath in heated sulpheric acid was one of the steps. You think that won't damage a spring? I think it would.Terry- Top
Which is why I said: ".... depending on the process used." If you are doing it yourself you can contlro the process. If you send them out there is no control.
The concentration of acid currently used in the phosphate solutions is very low, and even less once you dilute it 1:9 with water.Vice-Chairman (West), Michigan Chapter NCRS
Nice slope to the concrete floor too. Oh and my sinuses were pretty clear as well. OSHA and the EPA didn't exist back them. We may have been one of the reasons for them.
Terry- Top
