Rarest of the rare on auction
Re: Rarest of the rare on auction
THANKS JOEKen------
They didn't. The radiator used on the LT-1 was a copper/brass radiator but it was not the same one used for ANY big block. It might generally APPEAR like the radiator used for 1966-68 big blocks, but it's absolutely not the same piece.
Also, the L-88 and ZR-2 did not use a small block radiator. They used an aluminum radiator that was similar to the 63-72 small block aluminum radiator, but it was not the same. The L-88 and ZR-2 radiator was GM #3007436, the same radiator used for most 1965 L-78's. This radiator was primarily a big block radiator (i.e. L-78, L-88, ZR-2). The only small block application it was ever used on was 1970-72 ZR-1.
I knew that they wern't the same. I was speaking the use of the seperate overflow tank. 63 and up SB, 65 BB had overflow cans,66 to 69BB & 70 LT'1 had none but 454 & ZR-1 did. What was the reason for the switch. If one way worked better why not use it & just change size of the radiator & # of cores for different engines & applications?
KEN
KEN65 350 TI CONV 67 J56 435 CONV,67,390/AIR CONV,70 454/air CONV,
What A MAN WON'T SPEND TO GIVE HIS ASS A RIDE- Top
Ken-----THANKS JOE
KEN
KEN
The early aluminum radiators used in 63-72 Corvettes (as well as 60-62) had no integral supply tanks. So, an external supply tank had to be used.
In general, copper brass radiators used integral supply tanks and, consequently, no external supply tank was necessary or was used. However, there is an exception to this rule. The exception is the copper brass radiators used for the vast majority of 1969-72 Corvette big blocks. These radiator did have integral supply tanks but they had no filler provisions. Instead, an external supply tank with filler provisions was utilized. Why was this done? I have no idea and have never been able to rationalize it. The only speculation I've been able to come up with is that the external supply tank had become kind of a "Corvette-unique" piece after its use in most C2's (except most 66-67 big blocks). So, maybe for 1969 they figured that all Corvettes needed to have one whether they needed it or not. This sounds dumb but I can't come up with any other reason.In Appreciation of John Hinckley- Top
AGAIN JOE THANKSKen-----
That was my thinking also. Engineers work in mysterious ways. You should some how get all the info. that you have learned over the years down on some sort of mediam. I am afraid that you & guys like you,AL G. & John Z, & others will not be here to pass on all the info to the next generation of Corvette people.
the remote expansion tank was used to get the air out of the system. the coolant came from the top of the rad in to the top of the expansion tank air space in the 1/2 filled remote tank and it went back out thru the bottom of the tank. also side mounted rad tanks had to have the coolant level at 3" below the top to allow for expansion with no expansion tankKen-----
In general, copper brass radiators used integral supply tanks and, consequently, no external supply tank was necessary or was used. However, there is an exception to this rule. The exception is the copper brass radiators used for the vast majority of 1969-72 Corvette big blocks. These radiator did have integral supply tanks but they had no filler provisions. Instead, an external supply tank with filler provisions was utilized. Why was this done? I have no idea and have never been able to rationalize it. The only speculation I've been able to come up with is that the external supply tank had become kind of a "Corvette-unique" piece after its use in most C2's (except most 66-67 big blocks). So, maybe for 1969 they figured that all Corvettes needed to have one whether they needed it or not. This sounds dumb but I can't come up with any other reason.- Top
Thanks Clemthe remote expansion tank was used to get the air out of the system. the coolant came from the top of the rad in to the air space in the remote tank and it went back out thru the bottom of the tank. also side mounted rad tanks had to have the coolant level at 3" below the top to allow for expansion with no expansion tank
But why did they go from one system to the other. Was there some reason that one system was used on some engines & different on others.
i guess it would be determined if the testing showed a need for better cooling and if the corvette was to be raced it would be a requirement. remember back in the day SCCA racing required the use of production parts- Top
Dick, 3 Documented ZR2 ConvertiblesBy no means am I endorsing the car but y'all are missing that it is 1 of 2. The other 10 were T top cars.
This particular car was supposedly sold at Bloomington 2 years ago for $500k. It was no saled at Monterey 3 months later at $345k. The only other ZR2 that I am aware of being sold in the last 3 years was a coupe that brought $325k real money. I saw it sold and I know the buyer. There may have been some private treaty sales that I am unaware of.
1 is a factory primer car.
I owned the Steel city gray coupe from Canada
I would like to own this car too !!!- Top
Steve, The green convertible ZR2 Is the best in the world @ 450kThe green conv. that proteam bought at Monterey last year was sold to an Indiana collector. PT paid 440 for it and I'll bet they made a profit so it gives you an idea of current pricing. I think the green car is a better car though. My guess is the 375 for the orange car.
I like the Orange convertible @ 350- 375k- Top
Re: 2nd Rarest of the rare?
And when you pulled it back into 4th gear at about 6,500 rpm's that was when you knew the difference between a L/88 and a LS-6. No substitute for cubic inches. Proteam has/had a '68 L/88, that one time in its life, had a built LS-6 open chamber in it. Was absolutely wicked on the street. Don't ask me how I know
, that was about 40 years ago....
Lemme see 1.2 miles from a 100 mph start
Dick Whittington- Top
