Re: 1969 stut rod bushing replacement - NCRS Discussion Boards
  • Jerry B.
    • August 31, 1994
    • 416
    Just a local mechanic replace all the strut rod bushings and reinstalled said assemblies. My question is, are there any special reassemble instructions needed that affects ride height?
    • 43213
    Jerry------
    None that come to mind.
      • 15596
      Shouldn't these be tightened at ride height, just like other suspension bushings? I believe failing to do so will affect ride height.
        • 43213
        Terry-------
        I don't think it will significantly affect ride height but it will definitely affect the durability of the bushings. All of the fasteners associated with the strut rods should only be tightened with the suspension normalized.
