'66 427/425 How often should Solid Lifters be Adjusted - NCRS Discussion Boards
  • John M.
    • April 30, 2004
    • 111
    How often should I adjust the solid lifters on my 1966 L72 427/425.
    • 15706
    Re: '66 427/425 How often should Solid Lifters be Adjusted
    It should be listed in the maintenance section of your CSM. Tell us what you find.
    • Larry T.
      • May 15, 2007
      • 404
      When I checked the CSM for frequency I could not find it, so I adjust when they start to clatter a little bit. I have been having to do a couple of mine a little to frequently for my taste so I will be changing all of the rocker arm nuts next time around to see if that helps. Some nuts definately feel a little loose.
      • John M.
        • April 30, 2004
        • 111
        Duke, I have looked at all of my CSM's and do not find anything that states how often or how many miles etc.. I would assume I need to do a valve adjustment everytime I do a tune up! I have put about 500 miles on the car since I purchased last fall. The engine has about 3,900 miles sinse a complet rebuild. The valves sound like they are clatering a slight bit. This is my first Corvette with solid lifters. Please let me know what you reccomend.
          • 15706
          The 1963 Corvette Shop manual calls for a valve lash check every 12K miles.
          That should work for you if you set them properly using my recommended lash (.020/.022") and the procedure for small blocks written up my John Hinckley and me that you can find at:
          http://www.lbfun.com/Corvette/Tech/vettetech.html
          • Clem Z.
            • January 1, 2006
            • 9427
            if you run it to the redline a lot you need to adjust more often than if you just cruse around.
