58 Temp Sending unit/283/230 - NCRS Discussion Boards
  • Brad H.
    • August 12, 2007
    • 724
    My temp gauge at start up jumps to 210 and does not come down until the heat is circulating good, is this a gauge problem or do I need a new temp sending unit?, Thanks, Brad.
  • David S.
    • August 9, 2009
    • 595
    Re: 58 Temp Sending unit/283/230
    I have a similar problem. A few minutes after the 58 is started the gauge jumps to 220. My temp gun shows the car is much cooler than that. The gauges were just done so I have a new temp sending unit being delivered tomorrow.
    Best,
    Dave
    • William C.
      • May 31, 1975
      • 6037
      Wouldn't hurt to check the coolant level if you haven't already.
      Bill Clupper #618
      • Brad H.
        • August 12, 2007
        • 724
        I did have to top that off but not much. Brad.
        • Stan G.
          • January 1, 1996
          • 106
          At start up temp will be room temp . Either sending unit or gauge , sending unit easier to check first .
          • Hank D.
            • January 1, 1999
            • 138
            Brad -
            If it tuns out you need to replace the sending unit, try the Wells TU-5 at Autozone. It works just fine in my 60 283/230.
            Hank
            • Brad H.
              • August 12, 2007
              • 724
              Thanks guys, what type of sealant to use on the threads before installing so as to not affect the reading? Thanks, Brad.
              • David S.
                • August 9, 2009
                • 595
                Brad,
                I just replaced the sender this afternoon. Didn't put any sealant on it (and no leaks). The one that came off had teflon tape. That's a no no.
                Dave
                  Dave
                  Not necessarily - NPT threads in that application provide excellent ground continuity, even with tape or dope. If it's goobered on heavily enough to interfere, it'll make the gauge read colder, not hotter.
                  • Brad H.
                    • August 12, 2007
                    • 724
                    John, are you saying that Paragon or C.C. unit can take some type of sealant, what would you use to keep from seeing coolant seepage after install? Thanks, Brad.
                      Brad -
                      I've always used a light film of TFE pipe dope on NPT fitting threads (before assembly). If the threads are in good shape, it doesn't take much torque to get a good seal.
                      • Brad H.
                        • August 12, 2007
                        • 724
                        Thanks John, forgot to ask can I take old temp unit out without any water flow or do I need to drain down radiator a bit? Thanks again.
                          You need to drain the coolant level down to below the level of the sending unit, or be really nimble; all the coolant above the level of the sender will come out of that hole as soon as you loosen the sender.
                          • Brad H.
                            • August 12, 2007
                            • 724
                            Thanks again John, Brad
