69 427/390HP Cam - NCRS Discussion Boards
69 427/390HP Cam
  • Don W.
    • September 30, 1997
    • 492
    69 427/390HP Cam
    Based on some old receipts I found from the prior owner; this is cam currently in the engine:
    Crane Energizer Cam 260
    Cam StyleHydraulic flat tappetBasic Operating RPM Range1,000-4,600Intake Duration at 050 inch Lift204Exhaust Duration at 050 inch Lift204Duration at 050 inch Lift204 int./204 exh.Advertised Intake Duration260Advertised Exhaust Duration260Advertised Duration260 int./260 exh.Intake Valve Lift with Factory Rocker Arm Ratio0.484 in.Exhaust Valve Lift with Factory Rocker Arm Ratio0.484 in.Valve Lift with Factory Rocker Arm Ratio0.484 int./0.484 exh.Lobe Separation (degrees)110Computer-Controlled CompatibleNoGrind Number260 H10
    The new recommendation is the Sealed Power CS1093M; This cam was probably the best STREET big block, flat tappet cam EVER devised.The CS1093M is an exact duplicate of the OE cam. It is built to the GM print."
    I cannot find the specs for the CS1093M; but I was wondering if anyone knows how it compares to the above Crane cam which is in the engine now?
    Don
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: 69 427/390HP Cam
    complete specs.
    Chevy 396-454ci Big Block 1965-96
    *Note: In order to use these camshafts in 1965-66 396/427ci blocks, it is necessary to machine a 3/16'' wide x 7/64'' deep groove in the rear main journal of the cam to allow oil flow to the top of the engine.
    SMOOTH IDLE, DAILY USAGE, OFF ROAD, TOWING, BRUTE LOW-END TORQUE, 1600-2200 CRUISE RPM, 8.0 TO 9.5 COMPRESSION RATIO ADVISED. Grind Number:260-H10Operating Range:1000-4500 RPMDuration Advertised:Duration @ .050'' Lift:Valve Lift w/1.7 Rockers:.484'' Intake / .484'' ExhaustLobe Separation Angle:Max Lift Angle:Open/Close @.050'' Cam Lift:
    • Don W.
      • 492
      Not being a cam expert: I'm not sure how they compare. It looks pretty much the same to me...Don
      • Clem Z.
        • January 1, 2006
        • 9427
        3883986(427/390 HP) cam as listed by GM. dur@.050 214/218 degrees,lift .460/.480,lobe centerline 115 degrees. the CS1093M is a mercury marine cam for BBC but i can not find any specs.
        • Don W.
          • 492
          I believe the 3883986(427/390 HP) cam is discontinued...Don
          • Clem Z.
            • January 1, 2006
            • 9427
            if you can find the specs on the CS1093M you can compare to the 3883986 specs
            • Don W.
              • 492
              Here's what I can find on google:
              SEALED POWER Part # CS1093M Category: Camshaft 396/350HP L34 HYD FLAT TAPPET SPECS-214/218,.461"/.480",115 DEG LSA
                • 43281
                Don------
                The L-34 cam was exactly the same as the L-36 and L-68. The GM cams are discontinued.
                  • 15706
                  Specs for all the Sealed Power/Speed Pro OE replacement cams from Federal Mogul are on the NAPA web site. All you need is the OE GM number or the FM replacement number.
