I could use some advice on the repair of my Holley 4150/3247 carb. I can not stop the leak between the secondary fuel bowl inlet & the 1" steel hex fitting that screw into it. I suppect that the threads in the fuel bowl are partially stripped. Are these fuel bowls still available? or is there a repair kit? or other procedure to fix this problem? If the fuel bowls are still available, what is the best source? Holley? Thanks, Glen.
66 L72 Holley 4150/3247 carb
Re: 66 L72 Holley 4150/3247 carb
I could use some advice on the repair of my Holley 4150/3247 carb. I can not stop the leak between the secondary fuel bowl inlet & the 1" steel hex fitting that screw into it. I suppect that the threads in the fuel bowl are partially stripped. Are these fuel bowls still available? or is there a repair kit? .....
Is there a brown fiber washer between the fuel inlet nut and the bowl ? Or is it a thin steel type ?
If it is the threads (and I doubt it, as the they are not a NPT type sealing type, and only provide compression of the nut/gasket/bowl junction) then it should be easy to locate a secondary bowl, as they were used on just about all center-hinge float bowls in the mid-late '60s (except the LIST 3124 of the L78).Last edited by Wayne M.; May 21, 2011, 04:31 PM.- Top
If it is the threads (and I doubt it, as the they are not a NPT type sealing type, and only provide compression of the nut/gasket/bowl junction) then it should be easy to locate a secondary bow, as they were used on just about all center-hinge float bowls in the mid-late '60s (except the LIST 3124 of the L78).- Top
