67 Steering Gear Lube - NCRS Discussion Boards
  • Jim D.
    • December 1, 1994
    • 82
    What is the correct steering gear lube to use in a stock, mannual, 67 L79, original gear box? Ready to add fluids to trans, engine, steering box, and rearend on frame off. Thanks Jim
    • 15706
    Re: 67 Steering Gear Lube
    The "special" GM Corvette steering gear grease in discontinued, and in its absence, I recommend a full synthetic NGLI #2 grease. Valvoline offers one - check their Web site, but then you have to find a retailer who stocks it.
    • Jim S.
      • August 31, 2001
      • 730
      The Saginaw engineers always told me to use a good grade of lithium based chassis grease.
      Gary Ramadei is now using Costal Uniplex premium, high temperature, lithium complex grease in his Corvette steering gear rebuilds. At one time he did use Mobil 1 synthetic grease but has gone back to the lithium based type. I don't remember why he changed.
      Jim
        • 43273
        Jim------
        The grease that GM originally specified for use in 63-82 Corvette steering gears was GM #1052084. That product was discontinued in May, 1997 and replaced by GM #12377985. The latter product remains available from GM and that is what I recommend. This product can also be used for most other chassis lubrication applications except wheel bearings, so it's a true "multi-purpose" lubricant.
        • Jim D.
          • December 1, 1994
          • 82
          Duke, Jim and Joe, thanks for the info. I will try to get the GM grease tomorrow, if not a high quality lithium grease.
          • Timothy B.
            • April 30, 1983
            • 5202
            I have used Lucas Red and Tacky, it has a 540* drop point so it's good around exhaust manifolds. Good Stuff..
