Door hinge pins and bushings parts no. help - NCRS Discussion Boards
    • 6950
    looking for the part numbers for the current gm door hinge pins and bushings for my 63 conv.. Thanks for your help Ed.
    • 43247
    Re: Door hinge pins and bushings parts no. help
    Ed----
    The bushings are GM #9721917. There are no pins currently available from GM for your application.
    • Randy S.
      • January 1, 2003
      • 586
      Ed----
      Joe,
      I just got a quote for my 66 the other day from my local dealer. the pins are 20046147 listed as years 73-82. I suspect these are the correct diameter pins but longer than original and have to be cut. So I have read in the archives as I am planning on doing this.
      Randy
        • 43247
        Originally posted by Randy Swartout (39156)
        Joe,
        Randy
        Randy------
        The GM #20046147 may work for C2's but they were never cataloged by GM for that application. Even for C3 applications they are considerably longer than the original pins and must be cut to proper length. Whether, or not, that's the only problem for C2 applications I do not know.
        • Randy S.
          • January 1, 2003
          • 586
          Ed----
          Are these bushings smooth or knurled, I found some online but there is no part number reference.
          Randy
            • 6950
            Randy------
            Joe, the C3 pins are what I was thinking, I can cut them down and make the same length.
            • Larry H.
              • May 31, 1994
              • 63
              Randy,
              #9721917 bushings are smooth.
              Larry #24649
