57 speedo gear - NCRS Discussion Boards
57 speedo gear
  • Ken G.
    • December 11, 2008
    • 98
    57 speedo gear
    When I purchased this car to restore I was told the 3 speed gearbox was rebuilt and just needed a gear to drive the speedometer. I purchased a new plastic gear that came with a short spring, washer and cotter pin. Unfortunately I do not have a blow up diagram of the xmission, but I am hoping that the gear just slides in and the spring-washer-cotter pin were not meant for this xmission???
    Please tell me this is so...
    Ken
  • Gary C.
    Administrator
    • October 1, 1982
    • 17969
    Re: 57 speedo gear
    Ken, exploded view of 3 speed transmission attached. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Bruce B.
      • May 31, 1996
      • 2930
      Re: 57 speedo gear
      Ken,
      The speedo gear just slides in.
      No springs, cotter pin or washer.
      • Ken G.
        • December 11, 2008
        • 98
        Re: 57 speedo gear
        Whew!
        Thanks everyone!
        Ken
          • 43289
          Re: 57 speedo gear
          Originally posted by Ken Grosslight (49775)
          Whew!
          Thanks everyone!
          Ken
          Ken------
          The DRIVEN gear does install just as has been described. However, for it to work properly it has to be a gear that's compatible with the DRIVE gear already installed in the transmission. Not all available nylon gears are necessarily compatible.
          • Ray K.
            • July 31, 1985
            • 375
            Re: 57 speedo gear
            Ken
            Do you have the fitting that holds the speedo gear?
            Ray
            • Ken G.
              • December 11, 2008
              • 98
              Re: 57 speedo gear
              thanks all
              Hi Ray, yes the fitting is there along with the securing plate and screw.
              Hope I was sold a compatible gear, it came from Grossmueller's
              Ken
              • Ray K.
                • July 31, 1985
                • 375
                Re: 57 speedo gear
                Ken
                Think you are good to go. You did not mention what color or tooth count gear you purchased, hopefully it will mesh correctly with the drive gear inside the trans and is also correct for your rear axle ratio.
                Ray
