Cleaning White Wall - NCRS Discussion Boards
Cleaning White Wall
  • Tom F.
    • September 20, 2009
    • 66
    Cleaning White Wall
    I read the post a few weeks back regarding getting yellow out of white walls.
    I'm probably dating myself, but back in the sixty's there was a product that was a paste that did a great job. Can anyone remember the name of the product?
  • Steven B.
    • June 30, 1982
    • 4000
    Re: Cleaning White Wall
    Tom, I can't recall the product name now but Mobil sold one like it under the Mobil name. I used both a couple of times and then mixed baking soda and toothpaste with similiar results, then went the easy route with Wesley's.
    Steve
    • Tom F.
      • 66
      Steve, Thanks for your input, I'm sure that the product manufacturer is long gone. You just don't see too many wide white walls running on the road these days.
      • Alexander C.
        • June 20, 2010
        • 353
        I used the Westley's Bleche White on my new tires for the first time last week. It worked great but the water running off was pretty milky white. I hope that was only because it was the first time
        • John F.
          • March 23, 2008
          • 2415
          Always rinse real good and wipe dry.
          • Donald O.
            • May 31, 1990
            • 1593
            I used to use a SOS pad from my Mom's kitchen back in the day.
            Now I use Westley's Bleche White and scrub it with a Scotch-Brite pad on a plastic handle, like the kind for scrubbing a BBQ grill.
            • Edward S.
              • December 1, 1986
              • 514
              In the early sixties I bought my first & only convertable a 57 olds 98, upon buying the car I had a new white top - at the same time I was working for a auto parts dist.. One of the product lines we stocked was Swaco WW cleaner available in a liquid or paste. I always wanted that top as clean as I could get it and at the same time I did not want to stain my paint - so I started to use Swaco Paste to do the top, started to just spray light coat of water on the top plus a heavy coat of water on the car in case some got on the car. I would put the paste on the top, use a soft brush and do the entire top at one time and then wash the whole thing off. The product did a great job on the top and my tires. I left the job, sold the car and could not find Swaco anymore. It was a light green paste, don't know if that's the product you are talking about.
              • Wayne G.
                • May 4, 2011
                • 75
                You gotta love UTUBE!
                • Tom F.
                  • 66
                  Edward Styczynski came up with the name of the white wall cleaner that I was trying to remember, SWACO. It was a great product and probably manufactured somewhere in the Northeast at the time. I had a "61" Impala with wide white walls and the paste did the very best job of getting them white. I did check the Internet, but could not come up with anything.
                  Ed, thanks for coming up with the name.
                  • Wayne G.
                    • May 4, 2011
                    • 75
                    Simple Green and a good nylon soft brush... does not yellow, does not dry them out, may require a little more effort.
                    Swaco I think that was made by another company a few years ago, I think Gaurdsman Products...
                    Coker Tire makes a Wide White cleaner... supposed to not harm them...
                    I think the Bleach is what yellows them over time? But Wesleys has been around forever... I have seen the old schoold tricks Gas, K1 and others from time to time, Brillo, SOS, 409, Fantastik, WINDEX, bulk engine degrease and a steam cleaner... Guess it one of those things that works best for ya. I don't think todays whitewalls are made like years past, are the retro repros just as good?, the new ones seem to scratch easier and dry out faster if one uses a good old whitewall brass bruss and cleaner.
                    • Tom F.
                      • 66
                      Thanks Wayne, Will give it a try.
                      Tom
