i have had a problem with the
bottom cove trim that is in front of my driver's door.
it is pushed forward when i open the door!
i've tried to adjust things
but have found that it's better
is i just leave it pushed forward 1cm
ooops, this is america..i meant 3/8"
of course, the piece will stick out a little bit
into the wheel well.
has anyone else had this problem?
thanks
iowa
thanks
iowa
My trim was not tight against the body due to the moulding clip being loose. I realigned the clip in the backsid eof the moulding, tightened it, and problem solved. Make certain you have the correct clips so the trim is tight against the body.
