SB Freeze Plugs-source - NCRS Discussion Boards
  • Rod K.
    • March 31, 1990
    • 441
    The '56-'57 JG says the engine block freeze plugs were plain, no size or logos were stamped into the bottom of the cup. Anyone know of a source for these? Thanks.
  • Gary B.
    • January 31, 1997
    • 6994
    Rob,
    You can get correct, no-logo freeze plug in brass from:
    Cresap Automotive Machine
    631 N Mechanic St
    Cumberland, MD 21502
    (800) 850-8794
    The cost is $2.95 per plug + S&H; about $34 total for a set of eight.
    Gary
    • Scott S.
      • September 11, 2009
      • 1961
      Re: SB Freeze Plugs-source
      Rod,
      If the original freeze-plugs for '56-'57 were steel instead of brass, LIC has them, no size or logo stamps (LIC p/n 21-41A).
      • Gary B.
        • January 31, 1997
        • 6994
        SB Freeze Plugs-source; brass vs. steel
        Scott,
        Originals were undoubtedly steel, not brass, but presuming the block and freeze plugs are to be painted, why not use brass and never, ever worry about one rusting though, as steel will eventually do? That's the plan for my '66 anyway.
        Gary
        • Scott S.
          • 1961
          Hi Gary,
          That is an excellent point. I thought I remembered reading in the archives that the judges check for steel or brass, but I'm not sure now. I just checked the "Mechanical" judging sheet, and I didn't see anything for freeze plugs.
          • Jim D.
            • 2883
            Since the steel ones have lasted more than 50 years, why go with brass? I picked up steel ones with no logos or other stampings from the local NAPA for about .50 each.
            Jim
            • Rod K.
              • March 31, 1990
              • 441
              Thanks for all the responses. My local NAPA says theirs have the size stamped in them, but I'll check with the other suggested sources. Appreciate the help.
              • Jim D.
                • 2883
                Put a little body filler in the stamping before you paint it then. No big deal and it can't be detected.
                Jim
                • Norris W.
                  • November 30, 1982
                  • 683
                  Jim
                  I've seen steel ones fail in less than 10 yrs in cars that sit around a lot. I think brass is an obvious choice given the trouble involved in changing leaky ones.
