1968 Tri-Power - NCRS Discussion Boards
1968 Tri-Power
  • Noel O.
    • November 1, 1999
    • 50
    1968 Tri-Power
    Can anyone recommend a test or series of tests that can be used to determine if a tri-power set up should be rebuilt? This one was done about 5 years ago, there are no issues that are readily apparent (no leaks etc). The only issues I can see is that car runs a bit rough until it has warmed up. Does anyone have any thoughts on the ideal secondary spring weight / color to use? Is there any way to get a more progressive feeling out of the Holley tri-power set up ( 4 speed / 4.11 rear)?
    Tuning tips etc?
    Thanks in advance for the help
  • Rich P.
    • January 12, 2009
    • 1361
    Re: 1968 Tri-Power
    Noel,
    over the years I did 4 L-89's a 69 15 years ago, a red 68 10 years ago a 67 (clone) and am doing another 69 right now. All 4 are 4:11 4 speeds. And if you can't fry the tires through the first 3 gears it's not running up to potential. The gold car I did 15 years a go was scary fast on the first 2 run through the gears then once it hit 200 degrees it lost 30-40 hp. The 68 was not quite as scary fast but did not lose power when it was at temp. Each car will have it's own personality.
    I would see if the distributor has the right set up and curve. And as far as the secondary springs. I would suggest getting a complete set and switch to 1 level lighter spring at a time to see when you can feel the difference.
    Rich
    • Patrick N.
      • March 10, 2008
      • 954
      Re: 1968 Tri-Power
      [quote=Rich Pasqualone (49858);553761]Noel,
      It might go without say, but as you try different springs, you will have to drive the car to put the end carbs under load-2000K + rpm (not sure of rpm) for the vacuum to kick in. The goal is to have a smooth transition in power increase when they do come online, not a jolt in the pants.
      Pat
      • Noel O.
        • November 1, 1999
        • 50
        Re: 1968 Tri-Power
        Thanks Guys
