Anyone have a recommendation of a transmission shop in Dallas to work on a my 67 Corvette's powerglide?
It's likely a combination of jammed/bent internal shift linkage, which occurred when I (whilst on jack stands) had the car running in gear, and shifted from reverse into park without hitting the brake (I was tired and not thinking).
I had the car back up on jack stands this morning to get a look at the external linkage. I decided to leave bad enough alone and get help.
Given the close quarters, the shift control lever rod being in backwards (based on the 63 shop manual and supplement, the clevis end is supposed to be at the bell crank transmission end, and mine's on the other end at the shifter), and visualizing the difficulty I may have putting things back if I tear into it and don't end up unjamming/fixing it myself, I just said nope.
Anyway, I am looking for recommendations better than the yellow pages of a transmission shop in Dallas, if anyone has one.
Second question: I see lots of sources for the external linkage online, but not the internal parking pawl, shift and parking actuator assembly levers--are those available anymore and from whom?
Thanks.
Thanks.
