63 Convertible Latchs And Release Handle Question - NCRS Discussion Boards
  • Edward J.
    • September 15, 2008
    • 6950
    My latches and release handle are painted body color is this correct?if not are the plated? Thanks, Ed
  • Stuart F.
    • August 31, 1996
    • 4676
    Re: 63 Convertible Latchs And Release Handle Question
    Ed;
    Mine are chrome plated. I trust you are referring to the front latches, but even the back deck hardware is chrome as well.
    Stu Fox
    • Edward J.
      • 6950
      Stu, I Should have specified exactly what pieces I was talking about, I was referring to the under side of the deck lid that releases it to open, The handle and latch mechanisms are painted on mine. Was this a done from the factory or when someone painted the car previous.
      • Alan D.
        • January 1, 2005
        • 2046
        Ed - maybe a little confusing Ref Sec 1.00 sheet C7.00 (that' the 64 AIM)
        latches- the small latch (lock asm) on the front side of deck when closed one can not see them. they hit a chrome section of metal to force them closed. #4 pn 3797331 On 64 they are painted.
        release handle- at front center underside (control asm), used to open the deck, #13 pn 3823148 On 64 they are painted.
        NOW you will need to confirm what was done for 63, early late or ....???
        You 63 guys have things tougher then most C2.
        • Kenneth S.
          • July 31, 1981
          • 302
          The lever, cables and latches on the underside of rear deck lid were in place when the car was painted at the factory.
          Ken
          • Wayne W.
            • April 30, 1982
            • 3605
            I agree with that Ken at least for the later cars, but for early ones, they definitely were not painted. I have worked on several. At least into the 360 ish range there was no paint on the under mechanisms. I dont know when the change in proceedure occured.
            • Stuart F.
              • August 31, 1996
              • 4676
              Now that we know what latches we're talking about, I can confirm that all my under deck hardware is painted body color. Mine is an early July build.
              Stu Fox
              • Edward J.
                • 6950
                Great info guys, I can now confirm that my March car has painted hardware, my car has had a couple of re-paints so I just wanted to be sure that this was correct.
                • Edward J.
                  • 6950
                  Wayne, I just looked at a 63 vin. no. 2127 and its around a Oct. built car and it has unpainted latches and cables and release handle. Wow- learned another anomaly about the 63 cars. so many of them.
