Re: C2 front sway bar / stabilizer bar Brackets, Bushings & Bolts
Scott,
they are just like I described except they are coarse thread instad of fine thread. Those would work for the battery tray. This is very interesting.... 65 was the last year for the fine thread brake/fuel line bolts (same as the spare tire tub mount bolts) in 66 they changed to coares thread bolts exceactly like yours but shorter. I would look to see if the AIM pt# changed from 65-66 or 67 for the A/C battery tray bolts.
The p washer you refer to is as you guessed a flat parts washer in this case it is extra wide and thick.
So check the threads that were cut into your frame for the battery tray to see if they are coarse or fine. If coarse they were factory installed bolts. Or yours is an anomally???? Cool stuff!!!
Scott,
