63 alternator concern - NCRS Discussion Boards
  • Joe R.
    • July 31, 1976
    • 4551
    Re: 63 alternator concern
    Michael,
    You have a weak battery AND the wires are reversed on your AMP GAUGE. See that you are running out of time but a simple fix. Didn't catch that this was the finish of a new project, new wiring harness etc.
    See you in Joplin,
    Joe
    • Michael H.
      • January 29, 2008
      • 7477
      Originally posted by Michael Garver (49693)
      Well...I performed Michael's test (turning the headlights on with the engine off). I found that, apparently, those particular headlights generate electricity, because the result was a large positive reading on the battery gage. I'm sure the Department of Energy will want the hear about this discovery.
      • Domenic T.
        • January 29, 2010
        • 2452
        #18
        Your amp guage is reversed if you turn the head lights on and show a charge.
        The discharge when the engine is running also supports that.
        DOM
        • Michael G.
          • November 12, 2008
          • 2157
          #19
          Joe, unfortunately, I had planned on leaving early this morning. Putting everything back together and fixing the wiring has delayed me long enough that making the drive from eastern Michigan to Joplin by Thursday at 5:00 PM is not going to be possible, especially with the weather system between here and there.
          This car had its first PV at Joplin in 1990, so I had hoped to make it there again, but, I'll have to delay judging until New Jersey in a few weeks.
          Mike
          1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
          1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
