Engine Shut Down - NCRS Discussion Boards
Engine Shut Down
  • Joseph O.
    • February 9, 2011
    • 3
    Engine Shut Down
    Hello
    My car ia a 1962 327 340 hp. When I get on a parkway and in second gear shifting about 3800 to 4000 rpm the engine turns off before I can shift. turning the key it starts right back up. If I shift without bringing to those rpms it's fine.I checked the wires at the distributor and the starter everything is tight. Any sugestions ? Thanks
    Joe
  • Stuart F.
    • August 31, 1996
    • 4676
    Re: Engine Shut Down
    Check your ballast resistor.
    Stu Fox
      Originally posted by Joseph OConnell (52904)
      Hello
      Joe
      Joe -
      Has this behavior just started or did it follow some other work done on the car? Does it occur in any other gear? Have you checked the glass fuel filter?
        • 6941
        Joe, almost sounds like the engine maybe running out of fuel under load.Higher RPMS require alittle more fuel. check fuel pump pressure and filter, May not be keeping up with demand.
        • Tom H.
          • December 1, 1993
          • 3440
          Make sure you don't have any kinks in any rubber fuel lines. Maybe getting sucked shut under load.
          Tom Hendricks
          Proud Member NCRS #23758
          NCM Founding Member # 1143
          • John S.
            • July 29, 2009
            • 640
            Hello
            Joe
            i would check the engine harness for a short. start with the wiring as it comes out of the firewall, maybe shielding is rubbing.
            • Clem Z.
              • January 1, 2006
              • 9427
              see if it will RPM just using light part throttle. if you can run it up at part throttle i would check the fuel pressure.
              • Joe E.
                • April 1, 1985
                • 77
                As Tom suggested the fuel line on the 62 has a rubber hose connection between the long line and the gas tank need to check this hose.
                • Joseph O.
                  • February 9, 2011
                  • 3
                  Thanks to all I'll check that rubber fuel line
                  Joe
                  • Bob H.
                    • July 31, 2000
                    • 807
                    Joe
                    I had a problem with my 62 cutting off intermittantly. All it took was acceleration or hitting a small bump.
                    It turned out to be a poor connection on the ignition switch. Simple to remove, clean and eliminate as a problem.
                    PS: I believe I found it by having a meter on the coil as I drove it then traced it back to the switch.
                    Bob
                    • Joseph O.
                      • February 9, 2011
                      • 3
                      Thanks I'll check
                      Joe
                      • Mike E.
                        • February 28, 1975
                        • 5138
                        Actually three rubber hoses; 1) tank to metal line that extends through the body (hose is under the gas tank cover) 2) from that metal line to the long metal line that extends along the frame, and 3) from the forward portion of that line to the fuel pump.
                        I'd not worry about the first two. The third; some reproductions are too long, and end up kinking when you try to route them from the long line to the fuel pump. There's also a 45 degree fitting on the pump that receives that. Sometimes individuals will not include that fitting, or will configure it at the wrong angle.
