Vent window removal - NCRS Discussion Boards
Vent window removal
+ More Options
Posts
  • Roger K.
    Infrequent User
    • November 17, 2008
    • 6
    Vent window removal
    How do I remove the driver side vent glass window without breaking or damaging it?
    I need to have the vent frame spot welded with a new pivot and I am being told the glass needs to be removed and the entire vent window frame and support removed from the car to accomplish it.
  • Rich P.
    • January 12, 2009
    • 1361
    Re: Vent window removal
    Heat the stainless up with a heat gun. This softens the byutel tape and then catch the edge of the stainless on the end of a table and pull the glass out. Wear gloves as you need to heat the stainless pretty good to soften the glue. Take your time and you wont bend the frame.
    Rich
