1963 coupe drip rails - NCRS Discussion Boards
  • David C.
    Infrequent User
    • February 7, 2011
    • 4
    looking for any help on information replacing drip rails.
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11326
    Re: 1963 coupe drip rails
    David, Are you talking about the metal gutters around the edges of the door opening, on the body?
    • David C.
      Infrequent User
      • February 7, 2011
      • 4
      Richard,
      Yes I have a 63 with some rust on both lower ends. should I replace the complete rail or just repair the sections?
      I googled drip rails and found a site with nos for $1100.00 a pair. Seems like a lot.
      Any advice you can offer would be great.
      Dave
      • Russ S.
        • April 30, 1982
        • 2162
        I just replaced a set on a 63. The repos looked and fit very nice and were way cheaper.They are really quite easy to replace. Drill the pop rivets at the front and then spot drill the spot welds.
        • David C.
          Infrequent User
          • February 7, 2011
          • 4
          Russ,
          thanks for the help, If I could where did you buy yours from?
          Dave
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11326
            Dave, Zip has them available. I just noticed they're on the website. M-3810
            Rich
            • David C.
              Infrequent User
              • February 7, 2011
              • 4
              rich,
              I DIDN'T THINK OF ZIP. THANKS AGAIN AND I'LL TELL JT HI
              DAVE
              • Russ S.
                • April 30, 1982
                • 2162
                David, I got them from Corvette Central. RS
                • Sydney G.
                  • February 1, 1994
                  • 444
                  Russ,
                  Did you also do the extension, or lower area of the drip rail where the seam is in the door jamb?
                  I'm guessing that would be a harder fix?
                  Syd
                  • Russ S.
                    • April 30, 1982
                    • 2162
                    Originally posted by Sydney Garber (23984)
                    Russ,
                    Syd
                    Syd, Yes I did also replace the extension. It really isn't very hard to replace either.It's not spot welded to anything just riveted. What was hard in my case is that the bird cage behind the ext was completely rotted out and that piece isn't repoed so I had too fabricate it myself.
