Correct AC Fuel Pump 40658 - NCRS Discussion Boards
  • Jeff P.
    • 799
    I've searched for past posts and found them all interesting. I came across a NOS # 40658 . It is a type that has screws on the bottom with a metal tab that had the number on it. All others are the pressed on type. When did the pressed on start. My car is a March 68 build. Thanks jeff
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
    • 43288
    Re: Correct AC Fuel Pump 40658
    Jeff------
    If you came across an AC type 40658 that had any screws on it, then you came across a fuel pump that was incorrectly stamped or incorrectly boxed. I know of NO AC type 40658 that ever had any screws used in any part of its construction, external or internal.
    • David L.
      • July 31, 1980
      • 3310
      In January 1994 I bought 4 NOS AC fuel pumps (for $5 each but not in boxes) stamped "DI 40658" on the flange ("DI" = April 1969) at the Corvette swap meet in Cypress Gardens, FL. The person that I bought them from had no idea of their application because he did not have any Chevrolet parts catalogs. They are the non-rebuildable type without the screws.
      AC # 40658 = GM # 6417337, correct for 1968 Corvette (327) and 1969 Corvette (350) models.
      GM # 6417337 was discontinued in August 1971 and replaced with GM # 6470110 (AC # 40709).
      Jeff,
      I assume that your NOS 40658 pump is an aftermarket pump without the "AC" casting.
      Dave
      • Jeff P.
        • 799
        Thank you Joe and Dave. I came across one on eBay as I described. I'm going to spring Carlisle , maybe I'll get lucky. Jeff
