59 Driver Side Lower Cove Moulding - see pic - NCRS Discussion Boards
  • John F.
    • January 1, 2000
    • 155
    What is the trick to attaching the nut on the last hole before the door? Does the door and hinge need to be removed? I have these two holes drilled (not sure if they are factory or from bubba) but they don't lead to the stud to attach the nut. See pics.
    • May 31, 1974
    • 8385
    Re: 59 Driver Side Lower Cove Moulding - see pic
    the last fastner isn't a threaded trim piece but rather a Z-shaped clip that fastens to the fiberglass with a sheet metal screw. be sure the sheetmetal screw is ground down such that it doesn't project above the Z-shaped piece, otherwise when you snap the stainless trim on the Z-shped piece, you'll put a dent in the stainless trim. mike
      • May 31, 1974
      • 8385
      Ps; If You Need The Z-shaped Trim Clips, Send Me Your Snail Mail Address And I'll Send Ya A Couple On The Cuff. Mike
      • Roger W.
        • January 29, 2008
        • 567
        The upper side molding also uses one of those clips next to the door.
