What is the trick to attaching the nut on the last hole before the door? Does the door and hinge need to be removed? I have these two holes drilled (not sure if they are factory or from bubba) but they don't lead to the stud to attach the nut. See pics.
59 Driver Side Lower Cove Moulding - see pic
Re: 59 Driver Side Lower Cove Moulding - see pic
the last fastner isn't a threaded trim piece but rather a Z-shaped clip that fastens to the fiberglass with a sheet metal screw. be sure the sheetmetal screw is ground down such that it doesn't project above the Z-shaped piece, otherwise when you snap the stainless trim on the Z-shped piece, you'll put a dent in the stainless trim. mike- Top
The upper side molding also uses one of those clips next to the door.the last fastner isn't a threaded trim piece but rather a Z-shaped clip that fastens to the fiberglass with a sheet metal screw. be sure the sheetmetal screw is ground down such that it doesn't project above the Z-shaped piece, otherwise when you snap the stainless trim on the Z-shped piece, you'll put a dent in the stainless trim. mike- Top
