1973 tilt or telescoping steering column - NCRS Discussion Boards
  • Kim F.
    • July 15, 2009
    • 80
    I wanted to know how much work is involved in adding tilt and a telescoping steering wheel to the car? Or can it be added at all?
  • Russ S.
    • April 30, 1982
    • 2163
    Re: 1973 tilt or telescoping steering column
    I believe it is just a matter of changing them. I can't think of anything that is different between the two types of columns.
      • 43263
      Kim-----
      It's basically a bolt-in installation. All you need is the complete steering column. However, that will be the problem; finding a good used column. The GM column is long-since discontinued. Any 1969-75 Corvette column will work. However, there are minor differences between the columns over the years for things like stalks and levers. Functionally as a unit, they're all interchangeable, though.
      • Russ S.
        • April 30, 1982
        • 2163
        An additional item you will need to address if you want your original key is switching your original ignition switch for the one in the tele column-no small task.
        • Kim F.
          • July 15, 2009
          • 80
          Thais for the help on this one. I am now going to search for the steering column.
          • Kim F.
            • July 15, 2009
            • 80
            Typing too fast. Thanks!
            • Michael M.
              • February 1, 1993
              • 605
              Kim, when you find a telescopic steering column and you want to use your same ignition key let me know. I have rebuilt hundreds of these steering columns and I can help you with the ignition cylinder change.
