looking for confirmation on which radiator sould be installed in my 61 corvette 315Hp fuelie. my vin is 10867s110390, engine code f 0512 cs,block 3756519 dated D241.
radiator 61 corvette
Re: radiator 61 corvette
Originally posted by John Scopelite (50653)having a late 61 with the fuel injection and high lift cam, nolan's restoration guide states the radiator part number is 3151116. the other later 61s with lesser hosepower have radiator part #3150916. (both radiators are aluminum with a seperate surge tank)
John-----
I do not think the GM #3151116 uses a separate supply tank. At least, GM says that the 3151116 is configured with an integral top tank.
The GM #3150916 does use a separate supply tank.
As far as I can tell, the GM #3150916 was used for all late 1961 applications, regardless of engine, and was used for all 1962 Corvettes.In Appreciation of John Hinckley- Top
Nooland is a good friend. He has admitted that there are a number of errors in his book--you need to look at GM documentation, previous articles in the Restorer, and many original unmolested cars to get a true picture for what really happened.Originally posted by John Scopelite (50653)having a late 61 with the fuel injection and high lift cam, nolan's restoration guide states the radiator part number is 3151116. the other later 61s with lesser hosepower have radiator part #3150916. (both radiators are aluminum with a seperate surge tank)- Top
thanks joe, with the information you and mike have provided i now have the numbers straight. the late date code on a 3151116 radiator had me confused!John-----
As far as I can tell, the GM #3150916 was used for all late 1961 applications, regardless of engine, and was used for all 1962 Corvettes.- Top
so does every one agree that I should be using the 3150916 coase some one just informed me of a 3147516 that I possibly should be using- Top
