radiator 61 corvette - NCRS Discussion Boards
  • Al H.
    • February 25, 2011
    • 2
    looking for confirmation on which radiator sould be installed in my 61 corvette 315Hp fuelie. my vin is 10867s110390, engine code f 0512 cs,block 3756519 dated D241.
  • Mike E.
    • February 28, 1975
    • 5141
    Re: radiator 61 corvette
    As per the JG, aluminum radiator with separate aluminum expansion tank.
    • John S.
      • July 29, 2009
      • 640
      another item i read is that until midyear all 61 radiators were unpainted. yours being a late car will be painted a black enamel.
        • 43247
        Originally posted by John Scopelite (50653)
        having a late 61 with the fuel injection and high lift cam, nolan's restoration guide states the radiator part number is 3151116. the other later 61s with lesser hosepower have radiator part #3150916. (both radiators are aluminum with a seperate surge tank)
        John-----
        I do not think the GM #3151116 uses a separate supply tank. At least, GM says that the 3151116 is configured with an integral top tank.
        The GM #3150916 does use a separate supply tank.
        As far as I can tell, the GM #3150916 was used for all late 1961 applications, regardless of engine, and was used for all 1962 Corvettes.
        • Mike E.
          • February 28, 1975
          • 5141
          Nooland is a good friend. He has admitted that there are a number of errors in his book--you need to look at GM documentation, previous articles in the Restorer, and many original unmolested cars to get a true picture for what really happened.
          • John S.
            • July 29, 2009
            • 640
            John-----
            thanks joe, with the information you and mike have provided i now have the numbers straight. the late date code on a 3151116 radiator had me confused!
            • Al H.
              • February 25, 2011
              • 2
              so does every one agree that I should be using the 3150916 coase some one just informed me of a 3147516 that I possibly should be using
