1965 Roadster Carpet Installation - NCRS Discussion Boards
  • Brenton M.
    • May 31, 2006
    • 66
    I'm installing new carpet in my 65 convertible that i purchased from AL-KNOCK, i did a lot of reading on this forum before attempting this project i received some very helpful advice that made this job go alot smoother, i have finished with the bulkhead, wheelhousing, in luggage storage area. I'm ready to install my two front pieces i need some help on how to cut carpet for seat rails, your help would be greatly appreciated. THANKS
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11345
    Re: 1965 Roadster Carpet Installation
    Brenton,
    I just went through the same thing on a '67 convertible. I found several threads in the archives about the seat rails for '65's, which are different from '67's.
    I used this string in my search(except 7 for the 5)...... "1965 carpet" seat cut
    I got quite a few posts about how and where to cut and placement of the rail plates, i.e. over or under the carpets, etc.
    Rich
    • David T.
      • April 30, 2006
      • 46
      There is a very good article including pictures of the installation of new carpet in a C2 in the June 2011 issue of Covette Magazine. It may be of some help.
      • Alan D.
        • January 1, 2005
        • 2050
        FYI;
        One other area to be concerned about is the drive side near where the accelerator bracket comes through just above the console. I recently had a computer failure and most carpet pictures were lost so I can not remember how the 65 was cut in that area. Perhaps your search shows it however I know for 64 the carpet needs to be trimmed in said area.
        • Brenton M.
          • May 31, 2006
          • 66
          Could someone please send pic. of the carpet seat cut out on 65 conv.
          THANKS
            Brenton -
            Photos below are the original carpet removed from a '66; I think the cutouts are the same as '65. If you look closely you can see the "flaps" at the front of each track.
            • Alan D.
              • January 1, 2005
              • 2050
              Was able to recover some of my carpet pictures, so here is the gas pedal area I was concerned with (note its for a 64, not sure how 65 was done)
              And one for a 65, note my 66 pictures are basically the same as John's however it appears that 65 were different.
              • Brenton M.
                • May 31, 2006
                • 66
                Brenton -
                Thanks John. The pic was very helpful that is what i needed.
                • Brenton M.
                  • May 31, 2006
                  • 66
                  [quote=Alan Drake (43261);547956]Was able to recover some of my carpet pictures, so here is the gas pedal area I was concerned with (note its for a 64, not sure how 65 was done)
                  And one for a 65, note my 66 pictures are basically the same as John's however it appears that 65 were different. Thanks Alan your pic were also very helpful.
