58 Bezels - NCRS Discussion Boards
58 Bezels
  • Brad H.
    • August 12, 2007
    • 724
    58 Bezels
    Do the trunk and hood ornaments, ( Bezels?) have the black rubber gaskets underneath for judging? Thanks, Brad.
    Re: 58 Bezels
    Brad -
    Do they show in the Assembly Manual illustrations?
    • Brad H.
      • August 12, 2007
      • 724
      Re: 58 Bezels
      John, the aim shows lots of stuff that get's overlooked and vice versa, venders show gaskets as well as the aim I believe, I want a yes or no from someone who has had their car judged with them on and what was the result, simple. Thanks again, Brad.
      • Frank P.
        • April 1, 1985
        • 64
        Re: 58 Bezels
        Brad:
        No gaskets
        Frank
        • Brad H.
          • August 12, 2007
          • 724
          Re: 58 Bezels
          Frank, thank you, am I, (all of us) seeing the gaskets on the aim as well as the vendor photos ( I'm sure ther the same) so why are they not supposed to be on the car's? Thanks again. Brad.
          • Bill M.
            • April 1, 1977
            • 1386
            Re: 58 Bezels
            Brad:
            I have the original emblems from my '59 and they had gaskets as delivered. I see they're not mentioned in the JG, but a knowledgeable judge may ding you if you don't have them. If you get dinged for having them, drag out the AIM.
            I'm assuming they are there to prevent water from getting into the trunk; not sure about the front, but it had a gasket too.
            Bill
            • Brad H.
              • August 12, 2007
              • 724
              Re: 58 Bezels
              Bill, Thanks again, just as we expected, if it's in the book, that is what should be checked and not what one thought is to be judged. I Will leave mine on. Brad.
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11334
                Re: 58 Bezels
                I have a 59. Just to clarify location, the seal, AIM E 3.00(rear) & 11.100(front), part# 3753163 seals the emblem at the backside/inside of the fiberglass panel on both front and rear. It is between the emblem outer rim and the FG, not the chrome bezel. You should not see the seal from the outside of the car.
                In '08 I had my car judged, had them installed as described, and had no deducts........other than a 'condition' hit for the original rear emblem.
                What you can get hit for is the incorrect fastening nuts. They should be a green color with 2 tangs for the installation tool. Not pal nuts or push nuts or machine nuts.
                Rich
                • Brad H.
                  • August 12, 2007
                  • 724
                  Re: 58 Bezels
                  Thanks again Rich for the reply. Brad.
