iowa 56 - NCRS Discussion Boards
iowa 56
  • David A.
    • July 31, 1999
    • 147
    Re: iowa 56
    it was working fine when i removed it.
    picture of it's bottom...
    • Paul J.
      • September 9, 2008
      • 2091
      Re: iowa 56
      Originally posted by David Ahrens (32690)
      no comments?
      i ordered a new one anyway!
      also, here is a picture of the fuel pump i removed
      during this 'engine bay freshing up'
      it looks to be a different year than the 56's
      what year is it?
      is it worth anything?
      thanks
      iowa
      David, all used parts are worth something, and used Corvette parts usually have a good market. You need to provide more information about the markings on the pump. If you check the archives there are tons of threads that will help you. Here's one of them...
      https://www.forums.ncrs.org/showthre...+pump&uid=2822
      With respect to your question on engine painting, the archives are also full of information, but here's a thread that should answer your question.
      https://www.forums.ncrs.org/showthre...ngine&uid=8897
      Paul
        #18
        Re: iowa 56
        The factory did NOT use primer before painting the engine...
        • David A.
          • July 31, 1999
          • 147
          #19
          Re: iowa 56
          thanks
          i'll get more info off this fuel pump
          any words of wisdom about the motor mount crack above?
          iowa
            #20
            Re: iowa 56
            The 'screw together' AC pumps are getting harder to find with each passing day. Clean up the sides of the mounting flange and you should find a 4-digit number sequence stamped there that corresponds to the pump's original part number.
            Early '56 pumps were '4262' while late pumps were '4346'. Both can be rebuilt with an overhaul kit and the early units are reasonably rare. So, don't throw this pump away!!!
            • Rod K.
              • 445
              #21
              Re: iowa 56
              A competent machine shop should be able to "V" the crack and weld it both sides, then grind flush so the block and water pump will seal correctly. Not a high tech job.
              • David A.
                • July 31, 1999
                • 147
                #22
                Re: iowa 56
                thanks for help about the mounting crack!
                i found the # on the fuel pump:
                6942 JE
                so it isn't right for my 56'
                was it used on a later vette?
                would anyone like to buy it?
                (is there a special place to to this?)
                thanks
                iowa
                • David A.
                  • July 31, 1999
                  • 147
                  #23
                  Re: iowa 56
                  i've noticed that when i painted
                  the engine bay fiberglass with
                  the black paint from 'corvette central'
                  that the rougher exposed areas of the fiberglass
                  stayed sticky or tacky for quite awhile
                  while the smooth areas dried within an hour or so.
                  will these areas every dry? and how long?
                  does anyone reglass and sand such areas smooth?
                  thanks
                  iowa
                  • David A.
                    • July 31, 1999
                    • 147
                    #24
                    Re: iowa 56
                    i found that after painting the fiberglass in my engine compartment
                    that the area's that were frayed, or rough,
                    remained 'sticky' after several days!
                    the smooth area's dried within about one hour.
                    did these frayed rough area's become dissovled some
                    by the thinner in the paint?
                    and will it eventually dry?
                    thanks
                    iowa
                    • David A.
                      • July 31, 1999
                      • 147
                      #25
                      Re: iowa 56
                      the 'freshing up' is coming along great!
                      • David A.
                        • July 31, 1999
                        • 147
                        #26
                        Re: iowa 56
                        these are the only parts
                        that remain for my power top.
                        i do have rotten canvas covering the original frame.
                        but.......this is a project for another winter!!
                        iowa
                          Re: iowa 56
                          iowa
                          David -
                          You may find this article useful when you tackle that project:
                          http://www.lbfun.com/warehouse/tech_...ower%20top.pdf
                          • James G.
                            • May 31, 1976
                            • 1556
                            #28
                            Re: iowa 56
                            6942 JE
                            thanks
                            iowa
                            Hi David,
                            Can't find #6942, but this website http://www.old-n-good.com/parts/fuel...el_Pumps.shtml
                            shows pumps in the 6000 series appear to be 1963 vintage applications.
                            • David A.
                              • July 31, 1999
                              • 147
                              #29
                              Re: iowa 56
                              hi john
                              thanks for the link to the article
                              i see they show a picture of the circuit bracker.
                              interestingly, they show the red wire from the starter
                              and the red wire to the power windows...
                              but not the tan wire that goes across the front of the firewall
                              and down thru the 4 hole grommet
                              and eventually to the power top
                              also i found this u tube video of how the power top is supposed to work
                              i'd never seen it done before!!!!!!!!!!!!!!!
                              dave
                              • David A.
                                • July 31, 1999
                                • 147
                                #30
                                Re: iowa 56
                                these rims, i believe reflect the original
                                color of my 56
                                what color is this?
                                iowa
