C6 Trim Codes - NCRS Discussion Boards
C6 Trim Codes
  • John T.
    NCRS Financial Officer
    • January 1, 1983
    • 292
    C6 Trim Codes
    Apparently online registration wants paint code, trim code and build date even for Sportsman. Question is how is this information decoded from the car (2010).
    John
  • Tom H.
    • December 1, 1993
    • 3440
    Re: C6 Trim Codes
    RPO's will be in the glove box. If you want, PM me your VIN and I will be glad to break it down for you !
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • George C.
      • December 1, 1988
      • 583
      Re: C6 Trim Codes
      John, Your paint and trim codes should be on the label on inside of glove box door. Your built (month/year) date is on the inside of the driver door.
      • Rick A.
        • July 31, 2002
        • 2147
        Re: C6 Trim Codes
        John,
        yepper - welcome to the new "green sheets"!!!!! as was mentioned, all the info you need are either on the driver's door or glove box
        Rick Aleshire
        2016 Ebony C7R Z06 "ROSA"
          • 15606
          Re: C6 Trim Codes
          It took mine 85U and 19I (working from memory, here) with no problem, but my understanding is the system will not retan that information for Sportsman. So once you get the codes, keep them someplace for easy access the next time you register your 2010 for Sportsman.
          I still can't remember the VIN of the 2008 -- it is too long. No similar problem for the 1970 though, but then I have owned the 1970 long enough remembering the VIN is no problem. I somehow don't think
          • Tom H.
            • December 1, 1993
            • 3440
            Re: C6 Trim Codes
            Hey John, just sent you a PM with your codes and day of build.
            Tom Hendricks
            • John T.
              • January 1, 1983
              • 292
              Re: C6 Trim Codes
              Thanks Tom.
              Problem solved.
              John
              • Tom H.
                • December 1, 1993
                • 3440
                Re: C6 Trim Codes
                Never a problem when you got us around !
                Tom Hendricks
