Man, have I gotten confused on '63 headlight buckets - NCRS Discussion Boards
  • Alan D.
    • January 1, 2005
    • 2049
    Re: Man, have I gotten confused on '63 headlight buckets
    Did a look for info on the subject and found some good information from Joe Ray as follows:
    "Actually there were three designs of 63 buckets.
    Type I Fiberglass on a steel frame. Fiberglass only covered the top and bonding adhesive in the ends. Headlight bulb frame screwed with two long chrome plated phillips head screws thru the front to the steel frame. Two screws from the sides.
    Type II Fiberglass on a steel frame with the fiberglass around the ends so no filler was required. Headlight bulb frame screwed with two long chrome plated phillips head screws thru the front to the steel frame. Two screws from the sides.
    Type III Metal like 64 thru 67"
    Hope this helps a little
