62 Converting back to cartridge filter - NCRS Discussion Boards
  • Michael F.
    • June 4, 2009
    • 291
    Re: 62 Converting back to cartridge filter
    John -
    The retainer clip keeps the spring from popping all the rest of the pieces off the end of the bolt. You might want to get the kit so you have all the right pieces.
    Whats the down side if you only have the bolt,washer,filter and none of the internal parts? Oil won't filter properly?
    • Mike E.
      • February 28, 1975
      • 5141
      You'll likely have a leak down the shaft and out the bottom of the cannister.
      Originally posted by Michael Frost (50487)
      Whats the down side if you only have the bolt and washer out of all the internal parts? Oil won't filter properly?
      • John F.
        • March 23, 2008
        • 2418
        #18
        I went to the LIC catalog and they show a steel tube as part of the kit. What is it for?
        • Don H.
          • December 1, 1981
          • 1494
          #19
          I think the tube is for installing the retainer which holds everything in (as previously mentioned). Don H.
