62 Converting back to cartridge filter - NCRS Discussion Boards
  • John F.
    • March 23, 2008
    • 2406
    I am converting from spin-on, back to cartridge. Took off the filter, then the converter. I replaced the gasket between the by-pass (???) and the block and replaced with the shorter bolts. Now I'm not sure of the order of the components. Cannister with long center bolt with copper washer on the outside, then the spring with the rubber end up into the cone shaped thing, then the cartridge on that. I put a new big ring gasket up into the groove that the cannister should mate with. Tightened pretty tight. Fired up the engine and oil all over coming from the cannister. Is there a schematic of the order of components? I just read that the cannister should be torqued to 20-25 ft lbs. Am I missing something? Gave up for the night rather than lay out in the driveway with a trouble light.
  • Ronald L.
    • October 18, 2009
    • 3248
    Re: 62 Converting back to cartridge filter
    John,
    Its not clear in your sequence if you changed - that is removed - the spin on flange and reinstalled the original style adapter.
    The seal goes between that and the block and with all the care possible, the same thing happened to me the first time, a quart or two on the ground instantly.
    It was most likely the seal got twisted or pinched.
    I put in a new hard seal and tightened it up hard and it was OK on the second attempt.
    • John F.
      • March 23, 2008
      • 2406
      I removed the spin on flange and the old rubber seal/gasket. I am positive that I got the new rubber seal in straight. I had to help the very last inch or so of the seal with a screwdriver. No holes poked in it. I will pull the whole works off again this afternoon and try again. Used to just tighten up by feel in the old days. Do I have the sequence of the spring,etc. correct? Is there a picture somewhere? I looked in the shop manual.
      • Ronald L.
        • October 18, 2009
        • 3248
        I am pretty sure the big box Vette stores have the assembly picture with the product.
        • Harry S.
          • July 31, 2002
          • 5293
          Complements of LIC.
          • John F.
            • March 23, 2008
            • 2406
            Just took the filter cannister off again. Here is what I have, plus the gasket up in the groove. The by-pass is bolted in place. (1) is there more than a copper washer on the outside under the head of the bolt? Is that all that seals it when tightened? (2) see the spring with rubber on one end and the cone shaped thing. How do they go in the bottom of the cannister over the bolt? After that the cartridge filter, with the rubber gasket.
            • Harry S.
              • July 31, 2002
              • 5293
              John, is that an aftermarket cannister. if yes, I believe the metal is thinner than an original.
              • Mike E.
                • February 28, 1975
                • 5137
                Where did the oil come from? Top of the cannister or the bottom? That would help a lot in knowing how to diagnose the issue.
                Mike
                • John F.
                  • March 23, 2008
                  • 2406
                  I think the oil was coming from around the top of the cannister. But I still need to know which way the spring goes on the inside. The rubber end up into the cone or down toward the bottom of the cannister. The new gasket looks okay and not twisted or broken.
                  • John F.
                    • March 23, 2008
                    • 2406
                    Not an after market cannister!
                    • John F.
                      • March 23, 2008
                      • 2406
                      Harry, see PM.
                        Here's the parts sequence from an LICS ad for their canister rebuild kit.
                        • John F.
                          • March 23, 2008
                          • 2406
                          John, It appears I am missing the steel and rubber washers and the retainer clip. Can I just get a regular steel and rubber washer to fit the bolt? Also which way does the spring go? Rubber end up or down? What purpose does the retainer clip serve? Doesn't the cone just go into the bottom of the cartridge?
                            John -
                            The retainer clip keeps the spring from popping all the rest of the pieces off the end of the bolt. You might want to get the kit so you have all the right pieces.
                            • John F.
                              • March 23, 2008
                              • 2406
                              Just ordered the kit but need a temporary fix. Which way does the spring go?
