C-1 Side Windows - NCRS Discussion Boards
C-1 Side Windows
  • Jerry C.
    • November 1, 1995
    • 741
    C-1 Side Windows
    Windows on my 59 roll up and down real hard. This car was just restored and I know there are things to do when restoring to solve this problem but I need help without taking it apart. Is the a lubrication product I can put on the side window frames to help them roll easier? Thanks in advance
  • Steven B.
    • June 30, 1982
    • 3990
    Re: C-1 Side Windows
    Jerry, I had difficulty with my windows after replacing regulators. My problem was adjusting/aligning the windows in the channels. The only lube I have ever used was Lubriplate on the regulators. Check the ST-12.
    Steve
    • Mike E.
      • February 28, 1975
      • 5139
      Sometimes the front window run is an old GM replacement part which was way too thin for the window to travel up and down. Don't know if that's the case with yours, but have seen it often.
      • Mike M.
        • May 31, 1974
        • 8389
        spray front and rear channel fuzzys with a teflon containing aerosol can(lowes, home depot). you'll have to repeat the spray on occassion . the repo fussys are thicker than originals +/or narrower than originals as mike ernst mentioned.
        • Steven B.
          • June 30, 1982
          • 3990
          Mike and Mike, correct you are, as always! I have my originals from the '57 and also ones I bought from Chevy OTC in '65. It looks like the newer are a bit narrower (without my glasses) and the whiskers are very long. I would be surprised if the original whiskers are as long as the newer ones.
          Steve
