67 tach question - NCRS Discussion Boards
67 tach question
  • Mark U.
    • June 7, 2009
    • 70
    67 tach question
    my tach has a red line of 6300 rpm-my car came with a 427-390hp engine and powerglide trans.I thought the redline was different for this car?
  • Robert G.
    • May 31, 1990
    • 429
    Re: 67 tach question
    Yellow line should start at 5700 rpm, red should start at 6000 and end at 6200- at least for manual trans. This 427/390 automatic says it was top flighted, so I'm guessing it's the same for auto. I've never heard of a 6300 redline.
    • Mark U.
      • June 7, 2009
      • 70
      my tach starts at 6300 yellow and red lines starts at 6500 ends 7000
      this car also has a 80lb oil pressure gauge
      checked the tank sticker and its a l 36 and m35 trans
      Any ideas?
      axle posi track
      775x15 4 ply tires
        Any ideas?
        Mark -
        Tach has been changed; the one you describe was only used on L-71's, L-89's, and L-88's.
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11360
          Hmmm, with the 80 lb oil pressure gauge, it may be that the entire instrument cluster was changed.....?
          There is a white label with red letters on the backside of the cluster, about 3"W x 1-1/2"H with a 2 letter designation in large font then smaller font description. The cluster pictured from a L71 435HP has the 6500 RPM tach and 80 lb oil gauge.
          "LB" is for L71 and other solid lifter engines which use the 6500 tach & 80 lb oil gauge. I'm told "LA" is for standard tach and 60lb gauge. I am told "LC" is another code but I am unsure of it's application. Maybe speed warning buzzer option?
          The rear speedo/tach cover also has a date code. It may tell you if there is a major delta between car build and cluster build.
          Rich
          • Stephen L.
            • May 31, 1984
            • 3162
            This is a cluster sticker "LC" for a 427/390 NO speed warning option. Red lettering. Its for an April 10 build date coupe. 60# oil pressure.
            LA = base engine
            LB = L71 L88
            LC = L36 L79 L68
            I don't know the designations for "Speed Warning Option" I believe the tag will be green lettering.
            • Ray G.
              • May 31, 1986
              • 1189
              From an early licorvette catalog.
              RED LA 5300 60 300 #6457982
              RED LC 6000 60 350 #6457985
              RED LC 6000 60 390 #6457985
              RED LC 6000 60 400 #6457985
              RED LB 6500 80 430 #6455364
              RED LB 6500 80 435 #6455364
              GREEN LG 5500 60 300 SPEED WARNING #6458840
              GREEN ?? 6000 60 350 SPEED WARNING #6459496
              GREEN ?? 6000 60 390 SPEED WARNING #6459496
              GREEN ?? 6000 60 400 SPEED WARNING #6459496
              GREEN ?? 6500 80 430 SPEED WARNING #6459495
              GREEN ?? 6500 80 435 SPEED WARNING #6459495
              I hope you dance
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11360
                Stephen, Coincidentally that cluster was dated 44 years ago yesterday.
                Ray, Too bad the latest catalog doesn't have that info, at least not apparent when I looked.
                Rich
                p.s. Good info in this thread. I remember searching for this reference material 5 months ago and couldn't find it in the archives.
                • Stephen L.
                  • May 31, 1984
                  • 3162
                  Anybody out there that has a 67 speed warning option cluster that would post the cluster sticker data along with engine type???
                  • Michael H.
                    • January 29, 2008
                    • 7477
                    Any ideas?
                    axle posi track
                    775x15 4 ply tires
                    Mark,
                    If you have a 66, the 80lb oil pressure gauge would be correct with a 390 HP. For 67 with 390 HP, the gauge would be a 60lb.
                    As mentioned, your tachometer is incorrect for a 390 HP though.
