C1 Transmission Mainshaft - NCRS Discussion Boards
  • John F.
    • January 1, 2000
    • 155
    Does the mainshaft get grease before it's bolted up to the tranny? if so, any recommendations on types?
    • 43219
    Re: C1 Transmission Mainshaft
    John------
    You can use any good EP chassis lube or engine assembly lube.
    • John F.
      • January 1, 2000
      • 155
      Joe- thanks for the reply. I was concerned about centrifugal force when the main shaft spins. I thought it might toss grease all over the clutch plate and was wondering if that would be a problem.
        • 43219
        John------
        The amount you should apply is MINIMAL; just a VERY LIGHT film and only to the splined section.
