C1 Battery J Bolts - NCRS Discussion Boards
C1 Battery J Bolts
+ More Options
Posts
  • Ian G.
    • September 3, 2007
    • 1138
    C1 Battery J Bolts
    Hi,
    is there any difference in the battery hold down J Bolts (J-bolts) used in C1 Corvettes? Are the JBolts used in 58-60 the same as in 61-62 for instance?
    I couldn't find anything in the archives and don't really want to buy every judging guide to answer the question :P
    I have a 59.
    Thanks!
  • Gary B.
    • September 30, 1987
    • 305
    Re: C1 Battery J Bolts
    I could not find a difference.
    • Paul M.
      • November 1, 1987
      • 142
      I believe there is a difference. The 58 thru 60 had a loop or U shape on the bottom. the 61 and 62 was more like a check or a 110 degree bend.
      • Gary B.
        • 305
        Paul is most likely correct.
        • Ian G.
          • September 3, 2007
          • 1138
          OK so in other words they look like the repro bolts in 61/62...
          • Paul M.
            • November 1, 1987
            • 142
            Yes the repros are correctr for 61 and 62.
            • Bob B.
              • March 1, 2003
              • 831
              Ian,
              As far as I am aware, the fishhook j-bolts were not actually used and are nearly impossible to get on. Attached is a pic of what I believe is an original j-bolt from my '60. It's not a fishhook for sure, but it's not a kink, either, being rounded. It's about 1/4 inch shorter than the repros, the repros being longer for easy installation.
              Bob
              • Bob B.
                • March 1, 2003
                • 831
                Ian,
                Well I just found out that editing doesn't include adding a pic! And each time I try to add it now, I get an error message. So, I'm going to try putting it on a new post.
                Bob
