1967 power glide ? - NCRS Discussion Boards
1967 power glide ?
  • Mark U.
    • June 7, 2009
    • 70
    1967 power glide ?
    is there a special trans used for a 427 powerglide car or will a 67 powerglide from any chevrolet fit the bill? I would like to make this as close to original as i can.
  • Mike M.
    • May 31, 1974
    • 8381
    Re: 1967 power glide ?
    the 67 vette and 67 pass cars with big blocks all shared the aluminum powerglide and altho the pass ca PG will function perfectly in your vette, there are #'s stamped and cast into the PG that will differ vette vs pass car PG.mike
      • 43213
      Mark------
      You can use a 1967 Powerglide from other Chevrolet models in a 1967 Corvette with 427 and Powerglide. However, many of the internal parts of the Powerglide used with small block cars is different from those used with big block cars. If the donor transmission comes from a passenger car with big block, there will be little difference between it and the Powerglide used with Corvettes and big block. However, if the donor transmission comes from a small block passenger car (or, even a small block Corvette), there will be significant internal differences. Among many other parts differences, the torque converter used for small block cars is different than that used for big blocks.
      • Stephen B.
        Infrequent User
        • March 10, 2018
        • 4
        Hey Mike,
        I know there were 207 1967 Tri-Power Powerglide cars produced. How many were convertible and how many were coupes?
          • 43213
          Originally posted by Stephen Barnet (64548)
          Hey Mike,
          Stephen------
          There's absolutely no way to know, for sure. Such records were never kept.
          • Stephen B.
            Infrequent User
            • March 10, 2018
            • 4
            Thanks Mike,
            One more...
            Do you know what the standard rear end was? FA etc?
            • Keith B.
              • September 15, 2014
              • 1581
              I believe a 3:08 was the rear gear for 427 and power glide. At least it is for the one I helped restore
                • 43213
                Thanks Mike,
                One more...
                Stephen------
                The standard rear gear ratio for L-36/L-68 with Powerglide and without C-60 was 3.36:1. Positraction was mandatory and the code was "AU". For L-36/L-68 applications with C-60 the standard ratio was 3.08:1 positraction and the code was "AT".
                The standard gear ratio for 300 hp with Powerglide was 3.36:1 with code "AK".
                • Stephen B.
                  Infrequent User
                  • March 10, 2018
                  • 4
                  • Stephen B.
                    Infrequent User
                    • March 10, 2018
                    • 4
                    Thank you for your info!
                    • Keith B.
                      • 1581
                      how long have you had it? the powerglide behind the 427 with a tri-power is like nothing else you will ever drive
